주요 콘텐츠로 건너뛰기
HP Compaq 2510p Bluetooth Adapter Replacement
필요한 것
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: 1 단계, 이미지 1개 중 1개
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: 2 단계, 이미지 1개 중 1개
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: 5 단계, 이미지 1개 중 1개
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Derek Kohansky
회원 가입일: 10/26/16
297 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G8
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 528
