주요 콘텐츠로 건너뛰기
HP Compaq 2510p WiFi Card Replacement
필요한 것
  1. HP Compaq 2510p WiFi Card Replacement, WiFi Card: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over and locate the RAM cover plate towards the left of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p WiFi Card Replacement: 2 단계, 이미지 1개 중 1개
    • Using your Philips screwdriver, unscrew both screws.
  3. HP Compaq 2510p WiFi Card Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the plate with your finger to remove it.
  4. HP Compaq 2510p WiFi Card Replacement: 4 단계, 이미지 2개 중 1개 HP Compaq 2510p WiFi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the screws at the top of the card and use your Philips screwdriver to remove them.
    • Be sure to ground yourself before touching components.
  5. HP Compaq 2510p WiFi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the card from underneath the top, using the spudger to leverage the card upwards. Then pull to release the card.
    • Always used ESD safe tools when repairing electronics. The black nylon spudger should be used whenever possible.
  6. HP Compaq 2510p WiFi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Pull on each of the wires connected to the card. They will easily pop off and the WiFi card will be released.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dan Champagne
회원 가입일: 10/21/16
184 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G8
3 회원들
안내서 5개를 작성함
댓글 한 개
what wifi cards does this notebook support?
plaui - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 7
전체 시간: 641
