주요 콘텐츠로 건너뛰기
HP Compaq 515 Wireless Card Replacement
필요한 것
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
  2. HP Compaq 515 Wireless Card Replacement: 2 단계, 이미지 1/1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
  3. HP Compaq 515 Wireless Card Replacement: 3 단계, 이미지 1/1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/1
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
  5. HP Compaq 515 Wireless Card Replacement: 5 단계, 이미지 1/1
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
  6. HP Compaq 515 Wireless Card Replacement: 6 단계, 이미지 1/2 HP Compaq 515 Wireless Card Replacement: 6 단계, 이미지 2/2
    • Slide the wireless card backing towards you to remove it from the laptop.
  7. HP Compaq 515 Wireless Card Replacement: 7 단계, 이미지 1/1
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
  8. HP Compaq 515 Wireless Card Replacement: 8 단계, 이미지 1/1
    • Remove the two .4 cm screws with a PH00 bit.
결론
Aleks B
회원 가입일: 03/19/18
337 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G1, Covino Spring 2018 UMass Dartmouth, Team S4-G1, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 227
