주요 콘텐츠로 건너뛰기
HP Compaq 6510b CPU Replacement
필요한 것
  1. HP Compaq 6510b CPU Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before starting, shut down the PC and disconnect sources of power.
    • Slide the battery disconnect hooks to eject the battery.
  2. HP Compaq 6510b CPU Replacement, Keyboard screws: 2 단계, 이미지 2개 중 1개 HP Compaq 6510b CPU Replacement, Keyboard screws: 2 단계, 이미지 2개 중 2개
    • Unscrew the three screws shown.
    • Open the RAM door to expose the next screw.
    • Unscrew the final keyboard screw.
  3. HP Compaq 6510b CPU Replacement, Keyboard clips: 3 단계, 이미지 3개 중 1개 HP Compaq 6510b CPU Replacement, Keyboard clips: 3 단계, 이미지 3개 중 2개 HP Compaq 6510b CPU Replacement, Keyboard clips: 3 단계, 이미지 3개 중 3개
    • Use a flathead or spudger to slide the clips toward the trackpad.
  4. HP Compaq 6510b CPU Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 HP Compaq 6510b CPU Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 HP Compaq 6510b CPU Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • Put the screen in a 180 degree position.
    • Gently pull the keyboard up at the display side.
    • Slide the keyboard to the display.
    • Flip the keyboard so the keys are touching the trackpad.
  5. HP Compaq 6510b CPU Replacement, Keyboard cable: 5 단계, 이미지 2개 중 1개 HP Compaq 6510b CPU Replacement, Keyboard cable: 5 단계, 이미지 2개 중 2개
    • Fold the ribbon cable back so you can access the connection.
    • Pull the black part of the connector up to unlock the cable.
    • Pull the ribbon cable up to disconnect it.
  6. HP Compaq 6510b CPU Replacement, Power Button panel: 6 단계, 이미지 2개 중 1개 HP Compaq 6510b CPU Replacement, Power Button panel: 6 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cable that connects to the top panel and remove the second RAM stick.
    • Insert a flat head screwdriver into the holes circled and rotate 90 degrees to pop the plastic clips.
  7. HP Compaq 6510b CPU Replacement, Fan: 7 단계, 이미지 1개 중 1개
    • Disconnect the fan cable and unscrew the fan screws.
    • Lift the fan at the CPU side and slide it toward the CPU to free it.
  8. HP Compaq 6510b CPU Replacement, Cooler: 8 단계, 이미지 3개 중 1개 HP Compaq 6510b CPU Replacement, Cooler: 8 단계, 이미지 3개 중 2개 HP Compaq 6510b CPU Replacement, Cooler: 8 단계, 이미지 3개 중 3개
    • Unscrew the cooler screws in the reverse order - 4 3 2 1.
    • Pry with a flathead to unstick the thermal pad on the chipset. (It can hold on pretty tight)
    • Pull the cooler up a bit on the CPU side, then rotate it as demonstrated in the second photo.
    • When the chipset pad has roughly reached the keyboard connector, pull it out in the direction of the coin cell battery.
  9. HP Compaq 6510b CPU Replacement, CPU: 9 단계, 이미지 3개 중 1개 HP Compaq 6510b CPU Replacement, CPU: 9 단계, 이미지 3개 중 2개 HP Compaq 6510b CPU Replacement, CPU: 9 단계, 이미지 3개 중 3개
    • Use the flathead screwdriver to rotate the lock to the unlocked position.
    • Grab the CPU as shown. This way the pins are not likely to get bent.
    • Place the new CPU in the socket.
  10. HP Compaq 6510b CPU Replacement, Alignment: 10 단계, 이미지 1개 중 1개
    • Make sure the "star" on the CPU is aligned with the socket.
결론
To reassemble your device, follow these instructions in reverse order. When you get to screwing on the CPU cooler, tighten them in numerical order. (1 2 3 4)
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
tmg86
회원 가입일: 03/10/22
654 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 19
전체 시간: 555
