주요 콘텐츠로 건너뛰기
HP Compaq 6510b Hard Drive Replacement
필요한 것
  1. HP Compaq 6510b Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP Compaq 6510b Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3/3
    • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
    • Remove the two 5mm JIS #1 screws with your screwdriver.
    • Carefully lift up the cover.
    • Carefully lift up the hard drive from the back and pull it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joseph Noudom
회원 가입일: 03/01/18
569 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 UMass Dartmouth, Team S2-G5, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 885
