소개
You will need to take out the keyboard as a part of replacing the heat sink. Know the steps to Keyboard Replacement before starting on this.
필요한 것
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Using two fingers, open the prongs holding the RAM
Then slide the RAM out from the socket
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
That was easy. Thanks man :)
Piece of cake ! Thanks. :)
