주요 콘텐츠로 건너뛰기
HP Compaq 6710b Keyboard Replacement
필요한 것
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Compaq 6710b Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Compaq 6710b Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP Compaq 6710b Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Khulan Orgil
회원 가입일: 04/14/15
1,171 평판
안내서 6개를 작성함
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 회원
CPSU-MANESS-S15S4G2
4 회원들
안내서 6개를 작성함
2가이드 댓글
No parts required to *replace* the keyboard?
David - 답글
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 5,325
