주요 콘텐츠로 건너뛰기
HP Compaq 6710b Power Button Panel Replacement
필요한 것
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Compaq 6710b Power Button Panel Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Compaq 6710b Power Button Panel Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: 3 단계, 이미지 2개 중 1개 HP Compaq 6710b Power Button Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: 5 단계, 이미지 1개 중 1개
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: 6 단계, 이미지 3개 중 1개 HP Compaq 6710b Power Button Panel Replacement: 6 단계, 이미지 3개 중 2개 HP Compaq 6710b Power Button Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Khulan Orgil
회원 가입일: 04/14/15
1,171 평판
안내서 6개를 작성함
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 회원
CPSU-MANESS-S15S4G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 20
전체 시간: 3,573
