주요 콘텐츠로 건너뛰기
HP Compaq C700 Battery Replacement
  1. HP Compaq C700 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
    • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taylor Johansen
회원 가입일: 10/20/16
690 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G6
3 회원들
안내서 6개를 작성함
1가이드 댓글
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 1,501
