주요 콘텐츠로 건너뛰기
HP Compaq C700 Fan Replacement
필요한 것
  1. HP Compaq C700 Fan Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Fan Replacement: 2 단계, 이미지 3개 중 1개 HP Compaq C700 Fan Replacement: 2 단계, 이미지 3개 중 2개 HP Compaq C700 Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Fan Replacement, Fan: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over so that you see the bottom.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver
  5. HP Compaq C700 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
  6. HP Compaq C700 Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  7. HP Compaq C700 Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the covering that houses the RAM modules.
  8. HP Compaq C700 Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  9. HP Compaq C700 Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  10. HP Compaq C700 Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Gently lift and pull out the card.
  11. HP Compaq C700 Fan Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Locate the power button connector wire. (This can be found where the keyboard sits.)
    • Using the tweezers, unhook the wire.
  12. HP Compaq C700 Fan Replacement: 12 단계, 이미지 2개 중 1개 HP Compaq C700 Fan Replacement: 12 단계, 이미지 2개 중 2개
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  13. HP Compaq C700 Fan Replacement: 13 단계, 이미지 2개 중 1개 HP Compaq C700 Fan Replacement: 13 단계, 이미지 2개 중 2개
    • Unplug the remaining wires using the tweezers.
  14. HP Compaq C700 Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Gently pull out the three wires.
  15. HP Compaq C700 Fan Replacement: 15 단계, 이미지 2개 중 1개 HP Compaq C700 Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Locate the four 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  16. HP Compaq C700 Fan Replacement: 16 단계, 이미지 1개 중 1개
    • Unhook the display connector wire.
  17. HP Compaq C700 Fan Replacement: 17 단계, 이미지 1개 중 1개
    • Gently disconnect the display by pulling it upwards.
  18. HP Compaq C700 Fan Replacement: 18 단계, 이미지 1개 중 1개
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  19. HP Compaq C700 Fan Replacement: 19 단계, 이미지 1개 중 1개
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  20. HP Compaq C700 Fan Replacement: 20 단계, 이미지 1개 중 1개
    • Locate and unplug the touchpad connection using the tweezers.
  21. HP Compaq C700 Fan Replacement: 21 단계, 이미지 3개 중 1개 HP Compaq C700 Fan Replacement: 21 단계, 이미지 3개 중 2개 HP Compaq C700 Fan Replacement: 21 단계, 이미지 3개 중 3개
    • Using the Opening tool, gently pry up the cover and remove it.
  22. HP Compaq C700 Fan Replacement: 22 단계, 이미지 1개 중 1개
    • Unplug the fan wire connection using the tweezers.
  23. HP Compaq C700 Fan Replacement: 23 단계, 이미지 1개 중 1개
    • Locate the 3 mm Phillips head screw.
    • Unscrew it using the PH0 screwdriver.
  24. HP Compaq C700 Fan Replacement: 24 단계, 이미지 2개 중 1개 HP Compaq C700 Fan Replacement: 24 단계, 이미지 2개 중 2개
    • Using the opening tool, gently pry up and remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Taylor Johansen
회원 가입일: 10/20/16
690 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G6
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 8
전체 시간: 1,362
