주요 콘텐츠로 건너뛰기
HP Compaq C700 Keyboard Replacement
필요한 것
  1. HP Compaq C700 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP Compaq C700 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP Compaq C700 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift up and remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Taylor Johansen
회원 가입일: 10/20/16
690 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G6
3 회원들
안내서 6개를 작성함
2가이드 댓글
er zijn 3 schroeven aan het keyboard
marcel - 답글
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
azusa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 933
