주요 콘텐츠로 건너뛰기
HP Compaq C700 Touchpad Replacement
필요한 것
  1. HP Compaq C700 Touchpad Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Touchpad Replacement: 2 단계, 이미지 3개 중 1개 HP Compaq C700 Touchpad Replacement: 2 단계, 이미지 3개 중 2개 HP Compaq C700 Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Touchpad Replacement, Touchpad: 4 단계, 이미지 1개 중 1개
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  5. HP Compaq C700 Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  6. HP Compaq C700 Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  7. HP Compaq C700 Touchpad Replacement: 7 단계, 이미지 1개 중 1개
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  8. HP Compaq C700 Touchpad Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift and pull out the card.
  9. HP Compaq C700 Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
  10. HP Compaq C700 Touchpad Replacement: 10 단계, 이미지 2개 중 1개 HP Compaq C700 Touchpad Replacement: 10 단계, 이미지 2개 중 2개
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  11. HP Compaq C700 Touchpad Replacement: 11 단계, 이미지 3개 중 1개 HP Compaq C700 Touchpad Replacement: 11 단계, 이미지 3개 중 2개 HP Compaq C700 Touchpad Replacement: 11 단계, 이미지 3개 중 3개
    • Unplug the remaining wires using the tweezers.
  12. HP Compaq C700 Touchpad Replacement: 12 단계, 이미지 1개 중 1개
    • Gently pull out the three wires.
  13. HP Compaq C700 Touchpad Replacement: 13 단계, 이미지 2개 중 1개 HP Compaq C700 Touchpad Replacement: 13 단계, 이미지 2개 중 2개
    • Locate the four 3 mm Phillips head screws.
  14. HP Compaq C700 Touchpad Replacement: 14 단계, 이미지 1개 중 1개
    • Unhook the display connector wire.
  15. HP Compaq C700 Touchpad Replacement: 15 단계, 이미지 1개 중 1개
    • Gently disconnect the display by pulling it upwards.
  16. HP Compaq C700 Touchpad Replacement: 16 단계, 이미지 1개 중 1개
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  17. HP Compaq C700 Touchpad Replacement: 17 단계, 이미지 1개 중 1개
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  18. HP Compaq C700 Touchpad Replacement: 18 단계, 이미지 1개 중 1개
    • Disconnect the touchpad connection using the tweezers.
  19. HP Compaq C700 Touchpad Replacement: 19 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry up all sides of the device cover.
  20. HP Compaq C700 Touchpad Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the cover by lifting it.
  21. HP Compaq C700 Touchpad Replacement: 21 단계, 이미지 1개 중 1개
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
  22. HP Compaq C700 Touchpad Replacement: 22 단계, 이미지 1개 중 1개
    • Use the tweezers to remove the touchpad wire connection.
  23. HP Compaq C700 Touchpad Replacement: 23 단계, 이미지 2개 중 1개 HP Compaq C700 Touchpad Replacement: 23 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
  24. HP Compaq C700 Touchpad Replacement: 24 단계, 이미지 1개 중 1개
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Taylor Johansen
회원 가입일: 10/20/16
690 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G6
3 회원들
안내서 6개를 작성함
1가이드 댓글
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 1,536
