주요 콘텐츠로 건너뛰기
HP Compaq Presario CQ56-110US CD Drive Replacement
필요한 것
  1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: 1 단계, 이미지 1/2 HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: 1 단계, 이미지 2/2
    • Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US CD Drive Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver to unscrew the four 5mm screws holding down the hard drive.
  3. HP Compaq Presario CQ56-110US CD Drive Replacement: 3 단계, 이미지 1/2 HP Compaq Presario CQ56-110US CD Drive Replacement: 3 단계, 이미지 2/2
    • Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
  4. HP Compaq Presario CQ56-110US CD Drive Replacement: 4 단계, 이미지 1/1
    • Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
  5. HP Compaq Presario CQ56-110US CD Drive Replacement: 5 단계, 이미지 1/1
    • Use plastic opening tools to pry open the CD Drive.
  6. HP Compaq Presario CQ56-110US CD Drive Replacement: 6 단계, 이미지 1/1
    • Use your hands to pull the CD drive out and remove it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Iyonna L. Tynes
회원 가입일: 02/15/17
446 평판
안내서 3개 작성하였습니다
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 800
