주요 콘텐츠로 건너뛰기
HP Compaq Presario V3000 Battery Replacement
  1. HP Compaq Presario V3000 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ricky Jaimez
회원 가입일: 07/20/16
387 평판
안내서 2개를 작성함
University of Memphis, Team 1-4, Kim SU 2016 University of Memphis, Team 1-4, Kim SU 2016 회원
UM-KIM-SU16S1G4
3 회원들
안내서 3개를 작성함
1가이드 댓글
I need the battery remove switch
Aadhi Dev - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 2,705
