주요 콘텐츠로 건너뛰기
HP Compaq Presario V3000 CD/DVD ROM Replacement
필요한 것
  1. HP Compaq Presario V3000 CD/DVD ROM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 CD/DVD ROM Replacement: 2 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 CD/DVD ROM Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 CD/DVD ROM Replacement: 3 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 CD/DVD ROM Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
  4. HP Compaq Presario V3000 CD/DVD ROM Replacement, CD/DVD ROM: 4 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 CD/DVD ROM Replacement, CD/DVD ROM: 4 단계, 이미지 2개 중 2개
    • Locate the CD/DVD ROM drive. In order to recover an important disc from the drive, locate the manual release hole.
    • Insert paper clip or other small diameter object to engage the release mechanism.
    • Apply slow, steady pressure until the drive pops out. The ejection mechanism in the manual release hole is small. Multiple attempts may be needed to eject.
  5. HP Compaq Presario V3000 CD/DVD ROM Replacement: 5 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 CD/DVD ROM Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the screw that secure the CD/DVD ROM drive.
    • Use Philips #0 screwdriver to remove the 2.5 x 5.0mm CD/DVD ROM screw.
    • Place the 2.5 x 5.0mm CD/DVD ROM drive screw on the magnetic project mat.
  6. HP Compaq Presario V3000 CD/DVD ROM Replacement: 6 단계, 이미지 3개 중 1개 HP Compaq Presario V3000 CD/DVD ROM Replacement: 6 단계, 이미지 3개 중 2개 HP Compaq Presario V3000 CD/DVD ROM Replacement: 6 단계, 이미지 3개 중 3개
    • Slowly remove the CD/DVD ROM drive from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Samuel Lootens
회원 가입일: 07/25/16
203 평판
안내서 1개를 작성함
University of Memphis, Team 1-4, Kim SU 2016 University of Memphis, Team 1-4, Kim SU 2016 회원
UM-KIM-SU16S1G4
3 회원들
안내서 3개를 작성함
1가이드 댓글
very helpful. thanks and regards
kayvee1234 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 2,031
