주요 콘텐츠로 건너뛰기
HP Compaq Presario V5303NR Battery Replacement
  1. HP Compaq Presario V5303NR Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Compaq Presario V5303NR Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • A switch is located below the battery, take your finger and push it over to the left.
    • The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
    • After this the battery should pop up and be dislodged
  2. HP Compaq Presario V5303NR Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from its socket.
결론
작성자
2다른 기여자 명과 함께
Ryan Dunn
회원 가입일: 03/18/18
197 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G3, Covino Spring 2018 UMass Dartmouth, Team S4-G3, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 219
