주요 콘텐츠로 건너뛰기
HP Compaq Presario V5303NR Disk Drive Replacement
필요한 것
  1. HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: 1 단계, 이미지 3개 중 1개 HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: 1 단계, 이미지 3개 중 2개 HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: 1 단계, 이미지 3개 중 3개
    • Turn the laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Remove the battery from its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Disk Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Compaq Presario V5303NR Disk Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
    • Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
    • Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
    • Keep the different types of screws separate from one another. They will only fit into holes created for screws of their size, and thus cannot fit into other screw holes.
  3. HP Compaq Presario V5303NR Disk Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Compaq Presario V5303NR Disk Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the laptops bottom panel.
  4. HP Compaq Presario V5303NR Disk Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Gently remove the disk drive from its socket.
결론
작성자
2다른 기여자 명과 함께
Christopher M Paiva
회원 가입일: 03/19/18
109 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G3, Covino Spring 2018 UMass Dartmouth, Team S4-G3, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G3
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 3
전체 시간: 169
