주요 콘텐츠로 건너뛰기
HP Compaq Presario V5303NR Keyboard Replacement
필요한 것
  1. HP Compaq Presario V5303NR Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Compaq Presario V5303NR Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Compaq Presario V5303NR Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Turn laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Lift the battery out of its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Compaq Presario V5303NR Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 5 mm and 4 mm screws shown, represented in red and orange, respectively, using a Phillips #0 Screwdriver.
    • Keep all different types of screw separate from one another; they are different sizes, and cannot fit into the other's spaces upon reassembly.
  3. HP Compaq Presario V5303NR Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the laptop right-side up.
    • Carefully open the laptop as far as it can.
  4. HP Compaq Presario V5303NR Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Compaq Presario V5303NR Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the metal spudger in the space between the switch cover and the F1, F5, F11 and Insert keys.
    • Use the spudger to carefully pry the cover plate away from the keyboard and laptop at the aforementioned locations. Remove the cover plate.
    • If it is possible to do so, it is advised to use a plastic spudger instead of a metal one. The metal spudger can damage the computer's internal components, but the plastic one may be too thick to fit in the gap.
  5. HP Compaq Presario V5303NR Keyboard Replacement: 5 단계, 이미지 3개 중 1개 HP Compaq Presario V5303NR Keyboard Replacement: 5 단계, 이미지 3개 중 2개 HP Compaq Presario V5303NR Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #0 Screwdriver to remove the 4 4mm screws shown in the second picture. As per before, keep them separated from the screws removed in step 2.
    • Carefully lift up the section of the keyboard closest to the screen. Slowly rotate it downwards until it is resting on top of the touch pad.
  6. HP Compaq Presario V5303NR Keyboard Replacement: 6 단계, 이미지 2개 중 1개 HP Compaq Presario V5303NR Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Using your fingers, carefully pull the ribbon cable connecting the keyboard and laptop toward the hinge. Continue until connecting cable is unplugged.
    • Remove keyboard from laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chris Obesky
회원 가입일: 03/16/18
617 평판
안내서 3개를 작성함
UMass Dartmouth, Team S4-G3, Covino Spring 2018 UMass Dartmouth, Team S4-G3, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 291
