주요 콘텐츠로 건너뛰기
HP Compaq Presario V6000 Cooling Fan Replacement
필요한 것
    • Remove all of circled screws.
    • Be careful not to lose or misplace any screws. We suggest using a magnet board to keep everything together.
  1. HP Compaq Presario V6000 Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
    • After removing the backs of the memory card and hard drive cover, gently remove the silver screen.
  2. HP Compaq Presario V6000 Cooling Fan Replacement: 3 단계, 이미지 1개 중 1개
    • After removing the back of the memory card and the back of the hard drive, remove the CD Drive by gently pulling it all the way out of the device.
  3. HP Compaq Presario V6000 Cooling Fan Replacement: 4 단계, 이미지 2개 중 1개 HP Compaq Presario V6000 Cooling Fan Replacement: 4 단계, 이미지 2개 중 2개
    • After all components are removed, use your hands to separate the base plate form the main housing. If your fingers can not separate the 2 pieces; insert the metal spudger to create space.
  4. HP Compaq Presario V6000 Cooling Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove all screw we have designated in the photo.
  5. HP Compaq Presario V6000 Cooling Fan Replacement: 6 단계, 이미지 1개 중 1개
    • After all screws are removed use metal spudger to pry the plastic housing away from the ports to separate.
    • Use light pressure when separating the plastic housing
  6. HP Compaq Presario V6000 Cooling Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Separate the motherboard from the rest of the components.
  7. HP Compaq Presario V6000 Cooling Fan Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq Presario V6000 Cooling Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Remove designated screws
    • Unplug the ribbon connecting the cooling fan to the motherboard.
    • After unplugging and unscrewing you will be able to detach cooling fan
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
adam
회원 가입일: 10/11/16
323 평판
안내서 2개를 작성함
Texas Tech, Team 38-4, Bennett Fall 2016 Texas Tech, Team 38-4, Bennett Fall 2016 회원
TTU-BENNETT-F16S38G4
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 1,153
