주요 콘텐츠로 건너뛰기
HP Compaq Presario V6000 Trackpad Replacement
필요한 것
  1. HP Compaq Presario V6000 Trackpad Replacement, Trackpad: 1 단계, 이미지 1/1
    • Use the metal spudger to gently remove the plastic plate from the rest of the top panel.
    • Be careful not to break the plastic tabs connecting the two top panels.
  2. HP Compaq Presario V6000 Trackpad Replacement: 2 단계, 이미지 1/1
    • Separate the connection of the top piece from the board.
  3. HP Compaq Presario V6000 Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove the connection from the keyboard to its housing.
  4. HP Compaq Presario V6000 Trackpad Replacement: 4 단계, 이미지 1/1
    • Separate the power connections.
  5. HP Compaq Presario V6000 Trackpad Replacement: 5 단계, 이미지 1/1
    • Unravel the wire.
  6. HP Compaq Presario V6000 Trackpad Replacement: 6 단계, 이미지 1/1
    • Remove the screws connecting the plastic housing to the screen.
    • Use caution when removing the last screen. Do no damage the screen.
  7. HP Compaq Presario V6000 Trackpad Replacement: 7 단계, 이미지 1/1
    • Make sure to grip the screen tightly and separate the top and bottom.
  8. HP Compaq Presario V6000 Trackpad Replacement: 8 단계, 이미지 1/2 HP Compaq Presario V6000 Trackpad Replacement: 8 단계, 이미지 2/2
    • Remove the screws that hold the track pad in place.
    • Remove the track pad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
adam
회원 가입일: 10/11/16
323 평판
안내서 2개 작성하였습니다
Texas Tech, Team 38-4, Bennett Fall 2016 Texas Tech, Team 38-4, Bennett Fall 2016 회원
TTU-BENNETT-F16S38G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 618
