주요 콘텐츠로 건너뛰기
HP Compaq Presario V6000 Wifi antenna card Replacement
필요한 것
  1. HP Compaq Presario V6000 Wifi antenna card Replacement, Wifi antenna card: 1 단계, 이미지 1/1
    • Grab a Type-Cross #1 screwdriver and unscrew the 3 screws and take off the cover of the wifi antenna card.
  2. HP Compaq Presario V6000 Wifi antenna card Replacement: 2 단계, 이미지 1/1
    • Use your finger tips to pry off the gray antenna connections.
    • Be careful to not pull the antenna wire too hard, you may cause damage to the connection permanently and/or motherboard.
    • The screwdriver is only being use to demonstrate which wire to remove. The screwdriver can potentially damage the motherboard if used improperly.
  3. HP Compaq Presario V6000 Wifi antenna card Replacement: 3 단계, 이미지 1/1
    • After removing the connection cable, remove the two screws that hold the wireless card to the motherboard.
    • Then gently remove card without causing any damage to card itself or surrounding parts.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hunter Griffin
회원 가입일: 10/11/16
104 평판
안내서 1개 작성함
Texas Tech, Team 38-4, Bennett Fall 2016 Texas Tech, Team 38-4, Bennett Fall 2016 회원
TTU-BENNETT-F16S38G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 713
