주요 콘텐츠로 건너뛰기
HP Compaq Presario cq62-214nr Motherboard Replacement
필요한 것
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: 5 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 5 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: 7 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 7 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: 10 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 10 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: 11 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 11 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: 12 단계, 이미지 3개 중 1개 HP Compaq Presario cq62-214nr Motherboard Replacement: 12 단계, 이미지 3개 중 2개 HP Compaq Presario cq62-214nr Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Unlatch the final cable and gently remove the Motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Roth Marcelin
회원 가입일: 10/06/16
744 평판
안내서 6개를 작성함
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G6
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 12
전체 시간: 1,179
