주요 콘텐츠로 건너뛰기
HP Compaq Presario cq62-214nr RAM Replacement
필요한 것
  1. HP Compaq Presario cq62-214nr RAM Replacement, Battery: 1 단계, 이미지 1/2 HP Compaq Presario cq62-214nr RAM Replacement, Battery: 1 단계, 이미지 2/2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. HP Compaq Presario cq62-214nr RAM Replacement, RAM: 2 단계, 이미지 1/2 HP Compaq Presario cq62-214nr RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Remove the three M2.5x5 mm Phillips screws securing the memory case.
  3. HP Compaq Presario cq62-214nr RAM Replacement: 3 단계, 이미지 1/2 HP Compaq Presario cq62-214nr RAM Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
  4. HP Compaq Presario cq62-214nr RAM Replacement: 4 단계, 이미지 1/2 HP Compaq Presario cq62-214nr RAM Replacement: 4 단계, 이미지 2/2
    • Remove the top RAM chip by lifting up and pulling it towards the left.
    • Once the top RAM chip is removed, remove the one underneath using the same method.
결론
Roth Marcelin
회원 가입일: 10/06/16
726 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 18
전체 시간: 596
