주요 콘텐츠로 건너뛰기
HP Compaq nc6400 Keyboard Replacement
필요한 것
  1. HP Compaq nc6400 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Keyboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Locate and remove the 3 screws holding the keyboard in place from underneath the laptop.
  6. HP Compaq nc6400 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP Compaq nc6400 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP Compaq nc6400 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Locate and remove the four retaining clips from the edge of the keyboard. To remove pry up gently on the outside edge of the plastic clip. Once the clip pops up pull it straight out.
  7. HP Compaq nc6400 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 HP Compaq nc6400 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • At this point the back of the keyboard should come up a bit. You may need to use a thin tool to pull it up, but in my case I only needed my hands. Once you have the back of the keyboard propped up as shown pull the keyboard gently towards the screen to remove. Be careful not to pull completely out because there are still connectors attached to it.
  8. HP Compaq nc6400 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq nc6400 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Now with tweezers or a gentle prying apparatus gently pull the lock on the retaining clip up to release each ribbon cable. It is important to only pull up on the lock and not the entire clip.
  9. HP Compaq nc6400 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 HP Compaq nc6400 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • At this point the keyboard should be completely detached and ready to be removed. Be sure to take your time installing the ribbon cables as these can be troublesome if not installed properly
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Frost
회원 가입일: 03/12/14
197 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-3, Cichon Spring 2014 UMass Dartmouth, Team 5-3, Cichon Spring 2014 회원
UMASSD-CICHON-S14S5G3
4 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 51
전체 시간: 2,922
