주요 콘텐츠로 건너뛰기
HP Compaq nc6400 Screen Replacement
필요한 것
  1. HP Compaq nc6400 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: 7 단계, 이미지 3개 중 1개 HP Compaq nc6400 Screen Replacement: 7 단계, 이미지 3개 중 2개 HP Compaq nc6400 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq nc6400 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: 10 단계, 이미지 2개 중 1개 HP Compaq nc6400 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: 11 단계, 이미지 2개 중 1개 HP Compaq nc6400 Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: 12 단계, 이미지 2개 중 1개 HP Compaq nc6400 Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: 13 단계, 이미지 2개 중 1개 HP Compaq nc6400 Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Luis Vazquez
회원 가입일: 09/24/13
401 평판
안내서 2개를 작성함
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 회원
CPSU-FORTE-F13S14G6
5 회원들
안내서 5개를 작성함
1가이드 댓글
Nicely done. Thanks?
Peter Q. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 25
전체 시간: 5,646
