소개
The maintaining of a clean fan promotes the smoothly functioning of the computer.
필요한 것
Carefully flip the device over so that the bottom is facing up.
Slide both of the latches to the left.
Now that you have unscrewed most of the bottom of the laptop, carefully flip it back over.
Press down firmly on the four latches shown in the photo to detach the key board. This will unlock the latches holding the keyboard down, doing this will grant you access to the inside of the computer.
Now your laptop should have no screws and no keyboard.
You should now be able to open up the base of the laptop. With a bit of force, detach the sides latches of the base by pulling them open carefully.
Your computer should now look like the provided photo, where you can see where the fan is located.
다른 한 분이 해당 안내서를 완성하였습니다.
