주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq nc8430 RAM Replacement
필요한 것
  1. HP Compaq nc8430 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: 4 단계, 이미지 1개 중 1개
    • Completely shut down the device and unplug any adapters and chords that are connected.
  5. HP Compaq nc8430 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: 6 단계, 이미지 1개 중 1개
    • Locate the RAM after you remove the covering.
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: 7 단계, 이미지 1개 중 1개
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: 8 단계, 이미지 1개 중 1개
    • Place your fingers firmly on the RAM and pull it up.
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: 9 단계, 이미지 1개 중 1개
    • Place fingers firmly on RAM and pull it to remove it.
결론
작성자
5다른 기여자 명과 함께
bryan ingram
회원 가입일: 03/27/17
101 평판
안내서 1개를 작성함
1가이드 댓글
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 39
전체 시간: 1,037
