주요 콘텐츠로 건너뛰기
HP DV7-4285DX LCD Replacement
필요한 것
  1. HP DV7-4285DX LCD Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure laptop is shutdown and unplugged from power adapter.
    • Slide the battery release latch to the left and remove the battery.
  2. HP DV7-4285DX LCD Replacement, Bottom Cover: 2 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement, Bottom Cover: 2 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement, Bottom Cover: 2 단계, 이미지 3개 중 3개
    • Unscrew the five screws holding the bottom cover for accessing the RAM, hard drive and wifi card.
    • Five Phillips #1
    • When removing the cover, start from the top edge and lift up.
    • Remove cover.
  3. HP DV7-4285DX LCD Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 HP DV7-4285DX LCD Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Remove the four screws holding the hard drive.
    • Four Phillips #1
  4. HP DV7-4285DX LCD Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 HP DV7-4285DX LCD Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Unplug the SATA connection using the black pull tab.
    • Remove hard drive
  5. HP DV7-4285DX LCD Replacement, RAM: 5 단계, 이미지 1개 중 1개
    • Remove RAM by pushing the locking clips outwards.
  6. HP DV7-4285DX LCD Replacement, Wireless Card: 6 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement, Wireless Card: 6 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement, Wireless Card: 6 단계, 이미지 3개 중 3개
    • Use the edge of a plastic opening tool to pry the wifi antenna cable up from its socket on the wireless card.
    • Remove two screws from wireless card.
    • Two Phillips #1
  7. HP DV7-4285DX LCD Replacement, Optical Drive: 7 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement, Optical Drive: 7 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement, Optical Drive: 7 단계, 이미지 3개 중 3개
    • Remove the one screw holding the optical drive.
    • One Phillips #1
    • Use a spudger to push on the metal tab below where the screw was. This should disconnect the optical drive from the SATA connector.
    • Remove optical drive.
  8. HP DV7-4285DX LCD Replacement: 8 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 8 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the 26 screws on the bottom.
    • 20 Phillips #1
    • Three Phillips #0
    • Three Phillips #00
  9. HP DV7-4285DX LCD Replacement, Keyboard: 9 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement, Keyboard: 9 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement, Keyboard: 9 단계, 이미지 3개 중 3개
    • To the left of the battery connector is a keyboard release latch. Use a spudger to release the keyboard.
    • You may have to open the laptop some to keep the keyboard from re-latching.
    • Once freed, lift the keyboard up from the top.
    • Be careful not to damage or tear the ribbon cable.
    • Use the edge of a plastic opening tool to carefully flip up the retaining flap on the keyboard ZIF socket.
    • Remove keyboard.
  10. HP DV7-4285DX LCD Replacement: 10 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 10 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the two screws.
    • Two Phillips #1
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the three ZIF sockets.
  11. HP DV7-4285DX LCD Replacement: 11 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 11 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 11 단계, 이미지 3개 중 3개
    • Starting on the left side, use a spudger to pry the cover up. Work your way around to the right side.
    • Remove cover.
  12. HP DV7-4285DX LCD Replacement: 12 단계, 이미지 2개 중 1개 HP DV7-4285DX LCD Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the screw on the left side holding the lid hinge.
    • One Phillips #1
    • Use the black pull tab to remove the LCD connector.
  13. HP DV7-4285DX LCD Replacement: 13 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 13 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the screw on the right side holding the lid hinge.
    • One Phillips #1
    • Use a spudger to disconnect the speaker wire.
    • Carefully pull the wifi antenna wires out from the bottom case.
    • Remove lid.
  14. HP DV7-4285DX LCD Replacement: 14 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 14 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 14 단계, 이미지 3개 중 3개
    • Using a metal spudger remove the two hinge covers.
    • Use a metal spudger to remove the two screw covers.
  15. HP DV7-4285DX LCD Replacement: 15 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 15 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the two Phillips #1 screws that were under the covers.
    • Starting on the left side, use a spudger to pry the bezel up.
    • Work your way around and remove the bezel.
  16. HP DV7-4285DX LCD Replacement: 16 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 16 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the eight screws holding the LCD panel.
    • Eight Phillips #1
    • Use a spudger to disconnect the webcam connector.
    • Lift up the LCD panel.
    • The webcam wire is attached to the back of the panel. Carefully peel it off the panel.
  17. HP DV7-4285DX LCD Replacement: 17 단계, 이미지 1개 중 1개
    • Use a sudger to disconnect the wire from the LCD panel.
    • Remove LCD panel.
  18. HP DV7-4285DX LCD Replacement: 18 단계, 이미지 3개 중 1개 HP DV7-4285DX LCD Replacement: 18 단계, 이미지 3개 중 2개 HP DV7-4285DX LCD Replacement: 18 단계, 이미지 3개 중 3개
    • Remove the four screws (two on each side) holding the hinges on the sides.
    • Four Phillips #1 (two on each side)
    • Remove the hinges.
  19. HP DV7-4285DX LCD Replacement: 19 단계, 이미지 1개 중 1개
    • LCD remains.
    • To reassemble, follow these instructions in reverse order.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Patrick
회원 가입일: 03/30/12
501 평판
안내서 1개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 8,282
