주요 콘텐츠로 건너뛰기
HP Deskjet 1000 J110a Parts Replacement
필요한 것
  1. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: 1 단계, 이미지 1/3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: 1 단계, 이미지 2/3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: 1 단계, 이미지 3/3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a  Parts Replacement: 2 단계, 이미지 1/3 HP Deskjet 1000 J110a  Parts Replacement: 2 단계, 이미지 2/3 HP Deskjet 1000 J110a  Parts Replacement: 2 단계, 이미지 3/3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a  Parts Replacement: 3 단계, 이미지 1/1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Colin Tourjee
회원 가입일: 01/29/18
632 평판
안내서 4개 작성하였습니다
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G3
4 회원들
안내서 12개 작성하였습니다
댓글 2개
Very intuitive, good instructions. Highly recommended.
Krzysztof Białkowski - 답글
Thank you very much for the instructions on removing the cover to the HP 1200 Deskjet. It allowed me to removed a part that fell into the printer and prevented the paper from advancing.
karenliller@comcast.net - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 946
