주요 콘텐츠로 건너뛰기
HP Deskjet 1000 J110a Paper Control Sensor Replacement
필요한 것
  1. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: 1 단계, 이미지 1/3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: 1 단계, 이미지 2/3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: 1 단계, 이미지 3/3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Paper Control Sensor Replacement: 2 단계, 이미지 1/3 HP Deskjet 1000 J110a Paper Control Sensor Replacement: 2 단계, 이미지 2/3 HP Deskjet 1000 J110a Paper Control Sensor Replacement: 2 단계, 이미지 3/3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Paper Control Sensor Replacement: 3 단계, 이미지 1/1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: 4 단계, 이미지 1/3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: 4 단계, 이미지 2/3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the paper control sensor.
    • You can find the sensor, with the back of the printer facing you, on the right, and in front of the main circuit board. The paper control sensor will also be attached to a small circuit board. You will be replacing this circuit board.
    • Locate and unplug the connector which connects the sensor board to the main circuit board.
    • Use tweezers if unplugging by hand is too difficult.
  5. HP Deskjet 1000 J110a Paper Control Sensor Replacement: 5 단계, 이미지 1/2 HP Deskjet 1000 J110a Paper Control Sensor Replacement: 5 단계, 이미지 2/2
    • Locate and remove the 8mm screw with a screwdriver and the T10 torx bit, then remove the paper control sensor board.
    • In this picture, the main circuit board is removed. It is not necessary to remove the main circuit board unless the paper control sensor is not the only part being replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Colin Tourjee
회원 가입일: 01/29/18
632 평판
안내서 4개 작성하였습니다
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 42
전체 시간: 1,601
