주요 콘텐츠로 건너뛰기
HP Deskjet 1000 J110a Plug Ports Replacement
필요한 것
  1. HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: 1 단계, 이미지 1/3 HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: 1 단계, 이미지 2/3 HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: 1 단계, 이미지 3/3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Plug Ports Replacement: 2 단계, 이미지 1/3 HP Deskjet 1000 J110a Plug Ports Replacement: 2 단계, 이미지 2/3 HP Deskjet 1000 J110a Plug Ports Replacement: 2 단계, 이미지 3/3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Plug Ports Replacement: 3 단계, 이미지 1/1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: 4 단계, 이미지 1/3 HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: 4 단계, 이미지 2/3 HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: 4 단계, 이미지 3/3
    • Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
    • Remove each connector using tweezers if it is too difficult to remove them by hand.
  5. HP Deskjet 1000 J110a Plug Ports Replacement: 5 단계, 이미지 1/2 HP Deskjet 1000 J110a Plug Ports Replacement: 5 단계, 이미지 2/2
    • Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
    • Remove each connector by hand, as shown. You can use tweezers if it is too difficult to remove them by hand.
  6. HP Deskjet 1000 J110a Plug Ports Replacement: 6 단계, 이미지 1/3 HP Deskjet 1000 J110a Plug Ports Replacement: 6 단계, 이미지 2/3 HP Deskjet 1000 J110a Plug Ports Replacement: 6 단계, 이미지 3/3
    • Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
    • Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Perez
회원 가입일: 01/29/18
247 평판
안내서 2개 작성하였습니다
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 607
