소개
The plug ports are soldered onto the circuit board, so this is more of a circuit board replacement. Be careful when handling electronic circuit boards to avoid damaging the components and to avoid electric shock.
필요한 것
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
다른 한 분이 해당 안내서를 완성하였습니다.
