이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
