메인 콘텐츠로 스킵하기
소개
The one and only button on the HP Deskjet 1000 is the power button. If the power button is broken, you will be unable to turn the machine on. This guide will show you how to remove the button and then how to replace it.
부품
지정된 부품이 없습니다.
  1. Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped). Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped). Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  5. Carefully hold the small clip back to release the button arm. Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot. Replace the old power button with a new one.
    • Carefully hold the small clip back to release the button arm.
    • Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
    • Replace the old power button with a new one.
결론
Colin Tourjee
회원 가입일: 2018년 01월 29일
500 평판
안내서 4개 작성하였습니다
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G3
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 110
