주요 콘텐츠로 건너뛰기
HP Deskjet 1055 Buttons Replacement
필요한 것
  1. HP Deskjet 1055 Buttons Replacement, Buttons: 1 단계, 이미지 1/1
    • Press your thumb down on the center of the button plate located on the left side of the printer.
    • Hook your fingers underneath the front edge of the button plate and pull upwards making sure to keep pressure on the middle of the plate with your thumb.
    • When pulling up the front cover make sure to keep your thumb pressed firmly on the cover plate and bend up the front. Not doing so will result in breaking the tab that holds the back of the plate to the printer.
  2. HP Deskjet 1055 Buttons Replacement: 2 단계, 이미지 1/3 HP Deskjet 1055 Buttons Replacement: 2 단계, 이미지 2/3 HP Deskjet 1055 Buttons Replacement: 2 단계, 이미지 3/3
    • Once the front of the plate is loose, lift it up a few inches making sure to hold the back (paper feeding side) of the plate down.
    • Slide the plate towards the back of the printer and then lift up on the back of the plate.
    • The plate should now be disconnected from the tabs on the printer.
  3. HP Deskjet 1055 Buttons Replacement: 3 단계, 이미지 1/3 HP Deskjet 1055 Buttons Replacement: 3 단계, 이미지 2/3 HP Deskjet 1055 Buttons Replacement: 3 단계, 이미지 3/3
    • Turn the plate over to reveal the white strip of connecting tape that connects the plate to the printer.
    • Find where the tape is connected to the green button circuit board (Location circled in red)
    • Place two fingers on the tape right where it connects to the plate and gently pull the tape out of the circuit board.
  4. HP Deskjet 1055 Buttons Replacement: 4 단계, 이미지 1/1
    • Place the plate down on a flat surface with the button circuit board facing up.
    • Remove the three(3) T-10 Torx Screws from the circuit board.
  5. HP Deskjet 1055 Buttons Replacement: 5 단계, 이미지 1/1
    • Lift the button circuit board up and off of the button plate
  6. HP Deskjet 1055 Buttons Replacement: 6 단계, 이미지 1/2 HP Deskjet 1055 Buttons Replacement: 6 단계, 이미지 2/2
    • After Removing the circuit board you will be able to see the backside of the set of function buttons.
    • Lightly push each of the six tabs away from the clips holding them in.
    • Make sure to unclip all the tabs before pushing the buttons out of the plate. All the buttons are connected as a set and trying to remove them one at a time will result in them breaking.
    • Once all of the tabs are loose from their clips, push the set of buttons down and out of the button plate.
  7. HP Deskjet 1055 Buttons Replacement: 7 단계, 이미지 1/1
    • The power button is not clipped in and should easily slide off of the plate once the button circuit board is removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matt
회원 가입일: 10/09/12
88 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G18
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 2,038
