주요 콘텐츠로 건너뛰기
HP Deskjet 1055 Ink Cartridge Replacement
필요한 것
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 1/1
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: 2 단계, 이미지 1/2 HP Deskjet 1055 Ink Cartridge Replacement: 2 단계, 이미지 2/2
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: 3 단계, 이미지 1/1
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: 4 단계, 이미지 1/3 HP Deskjet 1055 Ink Cartridge Replacement: 4 단계, 이미지 2/3 HP Deskjet 1055 Ink Cartridge Replacement: 4 단계, 이미지 3/3
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: 5 단계, 이미지 1/2 HP Deskjet 1055 Ink Cartridge Replacement: 5 단계, 이미지 2/2
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: 6 단계, 이미지 1/1
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: 7 단계, 이미지 1/2 HP Deskjet 1055 Ink Cartridge Replacement: 7 단계, 이미지 2/2
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: 8 단계, 이미지 1/1
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
결론
When the power button stops blinking, your can now use your printer.
다른 4명이 해당 안내서를 완성하였습니다.
Daniel
회원 가입일: 10/06/12
314 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G18
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 21
전체 시간: 16,005
