주요 콘텐츠로 건너뛰기
HP Deskjet 1055 Motherboard Replacement
필요한 것
  1. HP Deskjet 1055 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 HP Deskjet 1055 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 HP Deskjet 1055 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Turn off the printer then open the top lid in order to see the inside of the printer.
    • Wait at least 15 minutes after turning off the printer before handling the motherboard.
    • After waiting 15 minutes, locate the blue tabs and gently pull them out of their sockets.
  2. HP Deskjet 1055 Motherboard Replacement: 2 단계, 이미지 1/1
    • Locate the three white plugs with wires attached to them. Gently grab the sides of the white chorded plugs and pull them out of their socket.
  3. HP Deskjet 1055 Motherboard Replacement: 3 단계, 이미지 1/2 HP Deskjet 1055 Motherboard Replacement: 3 단계, 이미지 2/2
    • Using a T-10 Torx screwdriver, unscrew the three 1/2'' screws on the motherboard.
    • Note which screws were taken out of their specific spot because they must me placed back to their original spot.
  4. HP Deskjet 1055 Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully pull the motherboard out of the printer.
결론
In order to reassemble your device, follow these instructions in reverse orders
다른 7명이 해당 안내서를 완성하였습니다.
Daniel
회원 가입일: 10/06/12
314 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G18
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
How to open Top part
sunny.2600 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 5,243
