소개
This guide shows you how to remove the button cover plate and the button circuit board in order to replace the latter.
필요한 것
Press your thumb down on the center of the button plate located on the left side of the printer.
Hook your fingers underneath the front edge of the button plate and pull upwards making sure to keep pressure on the middle of the plate with your thumb.
Turn the plate over to reveal the white strip of connecting tape that connects the plate to the printer.
Find where the tape is connected to the green button circuit board (Location circled in red)
Place two fingers on the tape right where it connects to the plate and gently pull the tape out of the circuit board.
다른 2명이 해당 안내서를 완성하였습니다.
