주요 콘텐츠로 건너뛰기
HP Deskjet 2624 Motherboard Replacement
필요한 것
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: 2 단계, 이미지 1/2 HP Deskjet 2624 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: 3 단계, 이미지 1/2 HP Deskjet 2624 Motherboard Replacement: 3 단계, 이미지 2/2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
결론
Ryan Doyle
회원 가입일: 01/16/20
578 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 545
