주요 콘텐츠로 건너뛰기
HP Deskjet 2624 Scanner Glass Replacement
필요한 것
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: 1 단계, 이미지 1/1
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: 2 단계, 이미지 1/2 HP Deskjet 2624 Scanner Glass Replacement: 2 단계, 이미지 2/2
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: 3 단계, 이미지 1/1
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: 4 단계, 이미지 1/1
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: 5 단계, 이미지 1/3 HP Deskjet 2624 Scanner Glass Replacement: 5 단계, 이미지 2/3 HP Deskjet 2624 Scanner Glass Replacement: 5 단계, 이미지 3/3
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: 6 단계, 이미지 1/2 HP Deskjet 2624 Scanner Glass Replacement: 6 단계, 이미지 2/2
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geoffrey Huse
회원 가입일: 01/16/20
148 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 31
전체 시간: 825
