주요 콘텐츠로 건너뛰기
HP Deskjet 3000 j310a Repair Printer Cover Replacement
필요한 것
  1. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Printer: 1 단계, 이미지 1/1
    • Begin to disassemble the printer by disconnecting from all power sources and computers. Keep cords separate and allow the printer to cool for 5 minutes.
  2. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Remove Bottom Cover: 2 단계, 이미지 1/1
    • Flip the printer upside down and locate the cover on the left hand side. It is rectangular shape and is held in place by two screws. Unscrew these screws and take off cover.
  3. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Release Paper Output Tray: 3 단계, 이미지 1/1
    • To release the tray from the printer, you must manually pull it out. Hold the tray and push towards one side of the printer. Then pull away from the printer towards the other side. Keep output tray separate.
  4. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Unscrew Cover: 4 단계, 이미지 1/1
    • Turn the printer upside down. Locate the four screws holding the cover in place. These will be on the edges of the cover.
  5. HP Deskjet 3000 j310a Repair Printer Cover Replacement: 5 단계, 이미지 1/1
    • Unscrew the four screws, keeping them separate. Turn the printer back right side up
  6. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Pull Off Top: 6 단계, 이미지 1/1
    • Place fingers on the edge of the red cover. Begin to pull upwards to release the top portion, working your way around the printer. Make sure that it does not fall back into place.
  7. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Cover: 7 단계, 이미지 1/2 HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Cover: 7 단계, 이미지 2/2
    • Once the top is loose, there will still be a connection wire between the printer and the cover. This wire will be about one inch wide and white, located under the buttons.
  8. HP Deskjet 3000 j310a Repair Printer Cover Replacement: 8 단계, 이미지 1/2 HP Deskjet 3000 j310a Repair Printer Cover Replacement: 8 단계, 이미지 2/2
    • Detach the wire from the printer by pulling the blue-sealed end from the white holder.
결론
tdambruoso
회원 가입일: 10/20/14
491 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-5, Duarte Fall 2014 UMass Dartmouth, Team 1-5, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G5
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 28
전체 시간: 569
