주요 콘텐츠로 건너뛰기
HP Deskjet 3522 Ink Cartridge Replacement
  1. HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 1/2 HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 2/2
    • Power printer on.
    • Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
  2. HP Deskjet 3522 Ink Cartridge Replacement: 2 단계, 이미지 1/2 HP Deskjet 3522 Ink Cartridge Replacement: 2 단계, 이미지 2/2
    • Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
  3. HP Deskjet 3522 Ink Cartridge Replacement: 3 단계, 이미지 1/1
    • Make sure you have the correct model number of ink that needs to be replaced.
    • For the HP Deskjet 3522 the required ink is HP 564 (Regular or XL)
  4. HP Deskjet 3522 Ink Cartridge Replacement: 4 단계, 이미지 1/2 HP Deskjet 3522 Ink Cartridge Replacement: 4 단계, 이미지 2/2
    • Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
    • Close the lid and allow the printer to recalibrate itself.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Melinda Singleton
회원 가입일: 10/09/14
182 평판
안내서 1개 작성함
USF Tampa, Team 1-30, Donnelly Fall 2014 USF Tampa, Team 1-30, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G30
1 회원
안내서 2개 작성하였습니다
댓글 한 개
These instructions were perfect to follow and complete.
walterawa1862 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 2,517
