소개
This guide gives step-by-step instructions for the removal and replacement of the Ink Cartridge for an HP Deskjet 6122. Following the directions outlined below should take approximately five minutes from beginning to completion.
Check to see if the printer is on. You can do this by identifying whether or not the bottom button on the right face of the computer is green. If button is green, proceed. If the button is not green, turn the printer on, and then confirm the bottom button is green.
The printer is reassembled and ready for alignment and test printing.
댓글 한 개
i have done this but my problem not solved,so this post was not work for me.
