주요 콘텐츠로 건너뛰기
HP Deskjet 930c Disassembly to clean Waste Ink Reservoir
필요한 것
  1. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir, HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 1 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir, HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 1 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir, HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 1 단계, 이미지 3/3
    • Carefully pry off the button board cover with a flat-head screwdriver.
    • Unplug and remove the button board.
    • Remove two screws that hold the printer's top piece in place with a TR8 Torx Security screwdriver.
  2. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 2 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 2 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 2 단계, 이미지 3/3
    • Remove the printer's lid.
    • Push in the tab shown to remove the top plastic assembly of the printer.
    • You don't have to remove the cartridge cover to do this. Though removing the cover makes it easier, it is not a required step.
  3. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 3 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 3 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 3 단계, 이미지 3/3
    • Remove the paper jam door from the printer by turning the dial from the locked position to the unlocked position.
  4. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 4 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 4 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 4 단계, 이미지 3/3
    • Push and lift the tabs shown with a flat-head screwdriver.
  5. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 5 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 5 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 5 단계, 이미지 3/3
    • Remove the top casing from the printer.
    • Unclip and pry off the side cover with a TR8 Torx Security Screwdriver.
    • Pry off the plastic casing with force; the TR8 Torx Security Screwdriver can help here.
  6. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 6 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 6 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 6 단계, 이미지 3/3
    • Remove the plastic piece covering the motor that controls the waste ink assembly.
    • Disconnect the motor connection.
  7. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 7 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 7 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 7 단계, 이미지 3/3
    • With the motor unplugged, move the ink cartridge carrier to the middle of the printer.
    • You can scroll the gear assembly with your finger if the carriage gets stuck.
    • Remove four screws from the back panel.
  8. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 8 단계, 이미지 1/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 8 단계, 이미지 2/3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 8 단계, 이미지 3/3
    • Press the clip marked in red.
    • Slide it to the right.
    • Lift and remove this side.
  9. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 9 단계, 이미지 1/2 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: 9 단계, 이미지 2/2
    • Press where marked with the arrow and lift the waste ink reservoir.
    • Remove the motor and clean with high-pressured water.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Bernard DU MORTIER
회원 가입일: 09/19/12
217 평판
안내서 1개 작성함
댓글 9개
Thanks so much, I was able to fix my bad paper feed jam on my Deskjet 952C using your disassembly instructions. Apparently you can take apart the 930C 932C 950C and 952C using similar methods.
kestrel77p - 답글
Merci pour l’aide.
Marc - 답글
Hello. Is it same too hp deskjet 9300?
chagii_r - 답글
I have no idea. I don’t have a HP deskjet 9300 printer.
Bernard DU MORTIER -
Many thanks for your instruction, Bernard. I was able to clean my DeskJet 970 cxi, because the waste ink leaked off the reservoir, as I transported the printer upside down :-( I’ve only got two additions, that I commented within the steps.
Heimwerker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 81
전체 시간: 14,844
