이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay the printer on its back.
Grab the paper tray by its right side and pull it to the left and up.
Open the frontal access panel by lifting it from the top.
Similar to the paper tray, grab it from the right side and pull it to the left and up.
Take out the two frontal 14.0 mm Torx #10 screws.
Carefully lift the frontal cover.
Looking at the printer from the front, carefully unhook the encoder strip from the left side.
Do the same thing on the other side by pulling to the right and pushing a little.
Pull the strip completely out from the cartridge holder.
다른 3명이 해당 안내서를 완성하였습니다.
