주요 콘텐츠로 건너뛰기
HP Deskjet D1660 Power Button Replacement
필요한 것
  1. HP Deskjet D1660 Power Button Replacement, Top Cover: 1 단계, 이미지 1/1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Power Button Replacement: 2 단계, 이미지 1/1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Power Button Replacement: 3 단계, 이미지 1/1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Power Button Replacement: 4 단계, 이미지 1/3 HP Deskjet D1660 Power Button Replacement: 4 단계, 이미지 2/3 HP Deskjet D1660 Power Button Replacement: 4 단계, 이미지 3/3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Power Button Replacement, Power Button: 5 단계, 이미지 1/1
    • Remove the strip that connects the printer to the front cover.
  6. HP Deskjet D1660 Power Button Replacement: 6 단계, 이미지 1/2 HP Deskjet D1660 Power Button Replacement: 6 단계, 이미지 2/2
    • Remove the two 13.0 mm Torx #10 screws.
    • Carefully lift it up. The button will be located under it.
  7. HP Deskjet D1660 Power Button Replacement: 7 단계, 이미지 1/1
    • Lift up the power button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Taiki Fukada
회원 가입일: 01/25/14
891 평판
안내서 7개 작성하였습니다
Cal Poly, Team 1-41, Maness Winter 2014 Cal Poly, Team 1-41, Maness Winter 2014 회원
CPSU-MANESS-W14S1G41
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 959
