주요 콘텐츠로 건너뛰기
HP Deskjet F4480 Ink Cartridges Replacement
  1. HP Deskjet F4480 Ink Cartridges Replacement, Open front access panel: 1 단계, 이미지 1/1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Ink Cartridges Replacement, Ink Cartridges: 2 단계, 이미지 1/1
    • Slide the ink carriage until the the cartridges line up with the marked slots in the middle.
    • If the printer is on, then the carriage should have automatically slid to the middle when the front was opened. If not, ensure printer is unplugged and slide manually.
  3. HP Deskjet F4480 Ink Cartridges Replacement: 3 단계, 이미지 1/2 HP Deskjet F4480 Ink Cartridges Replacement: 3 단계, 이미지 2/2
    • Gently, but firmly depress the front of the ink cartridge you are removing until it is loose.
    • There may be a faint click when the cartridge comes loose.
  4. HP Deskjet F4480 Ink Cartridges Replacement: 4 단계, 이미지 1/1
    • Gently slide out cartridge.
    • Don't make contact with the ink head. The ink likes to get everywhere.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tom Higdon
회원 가입일: 01/15/13
409 평판
안내서 1개 작성함
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 회원
CPSU-REGAN-W13S18G35
5 회원들
안내서 15개 작성하였습니다
댓글 4개
pls help me to operate to restore my hp deskjet f4480, I removed last wk the catridges to refill but when i starting to put back the catriges, i cant move the catriges holder, give me some tips pls, hoping a lot, ty
rico timbol - 답글
please the drivers may be installed for using the scanner
sarvani valluru -
My daughter took out the ink cartridges on my F4480 hp desk jet and I don’t know how they go in correctly please help
Kelly Cook - 답글
Why don’t you answer my question I just don’t want to force them or rake it
Kelly Cook - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 15,623
