소개
If there are communication problems between the computer and printer, replacing the motherboard is an option to consider in order to fix this problem. The motherboard controls all operations and functions of the printer enabling it to run properly and communicate with the computer.
필요한 것
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
Ken Craven - 답글
ou est localiser le sensor encoder module cb781-8006 merci
ou est installer le sensor encoder CB781-8006 Merci
