주요 콘텐츠로 건너뛰기
HP Deskjet F4480 Mother Board Replacement
필요한 것
  1. HP Deskjet F4480 Mother Board Replacement, Open front access panel: 1 단계, 이미지 1/1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Mother Board Replacement, Top Lid: 2 단계, 이미지 1/1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Mother Board Replacement: 3 단계, 이미지 1/3 HP Deskjet F4480 Mother Board Replacement: 3 단계, 이미지 2/3 HP Deskjet F4480 Mother Board Replacement: 3 단계, 이미지 3/3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Mother Board Replacement: 4 단계, 이미지 1/2 HP Deskjet F4480 Mother Board Replacement: 4 단계, 이미지 2/2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Mother Board Replacement: 5 단계, 이미지 1/3 HP Deskjet F4480 Mother Board Replacement: 5 단계, 이미지 2/3 HP Deskjet F4480 Mother Board Replacement: 5 단계, 이미지 3/3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  6. HP Deskjet F4480 Mother Board Replacement, Mother Board: 6 단계, 이미지 1/2 HP Deskjet F4480 Mother Board Replacement, Mother Board: 6 단계, 이미지 2/2
    • The mother board is located at the back of the printer.
  7. HP Deskjet F4480 Mother Board Replacement: 7 단계, 이미지 1/3 HP Deskjet F4480 Mother Board Replacement: 7 단계, 이미지 2/3 HP Deskjet F4480 Mother Board Replacement: 7 단계, 이미지 3/3
    • Take note of the wire's location and orientation as this will be important to properly reassemble your device.
    • Remove all of the wires connected to the mother board. There are seven in total.
  8. HP Deskjet F4480 Mother Board Replacement: 8 단계, 이미지 1/2 HP Deskjet F4480 Mother Board Replacement: 8 단계, 이미지 2/2
    • Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer
  9. HP Deskjet F4480 Mother Board Replacement: 9 단계, 이미지 1/1
    • At this point, the mother board should be free of all connections from the rest of the printer.
    • Remove and replace the mother board with the new one.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Allen Bailey
회원 가입일: 01/15/13
218 평판
안내서 1개 작성함
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 회원
CPSU-REGAN-W13S18G35
5 회원들
안내서 15개 작성하였습니다
댓글 3개
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
Ken Craven - 답글
ou est localiser le sensor encoder module cb781-8006 merci
viateur levesque - 답글
ou est installer le sensor encoder CB781-8006 Merci
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 33
전체 시간: 3,758
