이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Carefully lift the top panel off of the printer.
Do not tear or damage the two cables that connect the top lid to the motherboard.
Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Remove all of the wires connected to the mother board. There are seven in total.
Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer
At this point, the mother board should be free of all connections from the rest of the printer.
Remove and replace the mother board with the new one.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
Ken Craven - 답글
ou est localiser le sensor encoder module cb781-8006 merci
ou est installer le sensor encoder CB781-8006 Merci
